1966 Chrysler Town and Country Station Wagon - $3500 (Westminster, MD)
1966 Town and Country station wagon. 6 passenger, 383 big block, 727 automatic transmission. Power steering/ power brakes, electric rear window. Rear end is an 8-3/4 with Sure-Grip (posi-traction) and 2.76 ratio. Solid, mostly rust-free car from Arizona. Odometer reads around 77,000, true mileage unknown. Was on the road about 2 years ago, ran fine then. At that time a freeze plug on the engine leaked and I parked it. I have owned the car for approximately 5 years, and in that time have done the following:
- Flushed the gas tank
- Flushed and painted the radiator
- New belts and hoses
- Replaced the stock 2bbl intake and carburetor with a 4 barrel Edelbrock intake
- Installed a Mopar electronic ignition system to replace the points
- Cleaned and painted the valve covers, new gaskets
- Replaced the rear axle bearings and seals
- Repaired the speedometer
- Replaced the tires and brake shoes
I was in the process of replacing the heater core when the freeze plug started leaking. A new heater core comes with the car, but is not installed. There is also no carburetor or battery in it currently, so it will need to be towed.
The windshield is cracked and will need a new one. All other glass is good. The seats are in poor condition and the headliner is falling down and some of the interior trim on the doors, etc is cracked. See pictures.
As I said, this car came from Arizona. The only rust is in the lower areas behind the rear wheels, worst on the driver's side (see pictures). The floors, doors, etc are all very solid. Passenger front floor has surface rust only. All the suspension parts are solid.
Comes with the old 2bbl carb and a rebuild kit for it, the air filter housing, wiper arms, miscellaneous trim, and a new rear U-joint. Clear title in my name. No trades. Thank you.
https://baltimore.craigslist.org/cto/d/westminster-1966-chrysler-town-and/6873070430.html
