1970RT
Thanks man.You're an artist for sure!
My general go-by is for 1 amp per thousandth inch of thickness. 20ga is about .040, and I’ve found setups like this small flange will quickly heat soak. Larger panels have more capacity to absorb and disperse heat, hence why I use a lot of chill blocks and copper backers to keep the material together. The first three or four dabs with .035 70S-6 are slow, and the pace picks up from there. It’s maybe 10-12 dabs per inch, and then I air quench. For straight current on a fillet, 37 is in the lower end of the normal current range, but I’m getting a steady and stable full penetration on these with a blendable profile. When I use pulse, I’ll peak to about 53A welding the same joint.Are you saying you at the TIG set to 37 amps? I typically set mine up higher but move fast on sheet metal.
On these joints, the breakover from full pen to blowout is a fine one. I’m definitely being a bit conservative.
David
