Gold Rush
When I bought my '74 SE eight years ago the TQ leaked like really bad! Phenolic main body was warped and I could not locate a replacement. Bought a rebuilt TQ from Summit Racing. It ran and didn't leak but obviously needed tuned. That helped but still didn't run the way I remembered my original '74 SE did. Some time later I was doing some research and found the TQ Summit sold me as an exact fit for the '74 400 N code engine was not jetted correctly. Luckily, original jets and metering rods were interchangeable. Did that with significant improvement. While apart I went ahead and installed the full "HYGRADE" rebuild kit.
A couple months ago I discovered pump nozzles were not squirting well at all! At an engine builder friend's recommendation, I got a Walker rebuild Kit. I went through the entire typical rebuild sequence, including soaking in solvent. Lucky for me I had stumbled onto a really good rebuild manual actually published by Carter. It provided procedures to functional test the pump before assembling the carburetor. I went through three plungers and also three bore check valves (even had to coat the valve plate with gas proof sealer) before I got squirt. Fully assembled the TQ and got it installed this morning. WHAT A DIFFERENCE!!!!
Now the meat of this post. I suspect during the initial rebuild process too much material was removed from the pump bore inner wall; thus not getting good plunger seal and also not sealing the bore check valve completely. I see several sources for just the pump plunger and check valve. Some of the old style leather plungers are even still available. Does anyone have experiences similar to mine and found better sources for the pump parts?
BTW Here is a link to that manual I found.... Manual
