Garys1969RR
I have a 451 with 12.5 to 1 C/R. Mainly strip, and some limited street use. I have removed the thermostat as it was getting pretty warm last summer in all the heat. That helped it run alot cooler. And it helps when cooling the engine at the water towers after a run down the 1/4 mile. But I heard that I should be using at least a 160 degree thermostat, to get the engine up to operating temp more quickly. We know that a cool motor produces more horse power, and is less susceptible to pre-ignition. What are your thoughts on this, and are you using a thermostat in your high compression engine? Thanks.
