Russmacman
New Member
Hello all. 1978 Magnum. Finally have some time and resource to replace the engine. Removed everything frame out and reinstalled all new ball joints, and bushings all around. Installed the tie rod joints, and finger tight the drag link nut and Pittman arm nut on the center Link. Was going to put the end of the tie rod joints on the knuckle, but the angle seems so severe that I question if I have something put together incorrectly. Center Link has everything with a nut underneath and the tie rod joints going on the knuckle will have the nuts facing up. No engine in the car now and I thought I would give the T bars about 10 turns so far and no shocks installed as well. Does this look normal with no engine weight in the K frame? thank you.
