1967coronet440
Wookie, and myself are both using the competition engineering antiroll bar in conjunction with the street lynx. Helps launch that beast straight
I thought you were asking about which antiroll bar at one point? I've been discussing this long enough for you to have asked, got an answer that I missed, and installed it...It helps me pass the time between "I have some choices" and "thinking I have made a decision" to "I finally have the money to do ______" Lol.Wookie, and myself are both using the competition engineering antiroll bar in conjunction with the street lynx
I was asking at the time of our PM, since then my build went from a pro touring to a drag car lol. I linked up with wookie and picked his brain on how to launch the triangular 4 link in a straight line and he recommended the ARB, after that and my own research I went out and got one. For your application I don’t think you will need it. I would strongly consider an upgrade to the crusader line of Viking shocks for the rear instead of the standard warrior line if I were you though.I thought you were asking about which antiroll bar at one point? I've been discussing this long enough for you to have asked, got an answer that I missed, and installed it...It helps me pass the time between "I have some choices" and "thinking I have made a decision" to "I finally have the money to do ______" Lol.
Thanks guys!
I have already decided on a triangulated rear suspension, and it will come down to another conversation with Carl Gerst, the folks at Reilly Motor Sports, and probably one more thread on the forum as to which one of the two I get. The reason for not doing a true parallel 4 link, with a Watts or Panhard bar is that I plan on keeping the factory style fuel tank, which my understanding would have to be removed for either a Watts or Panhard bar to fit.
I will look at the Viking double adjustable shocks I put on the front for what "level" they are. All I know without looking is they were around $320 per pair. As far as the rear coil overs go, I knew that I would want whatever is best, and that is why I only got the Competition Engineering CEE-2730 for the rear for now for my stock leaf springs, the shocks I bought were gently used from a forum member, because they would give me something to work with until I can get the triangulated rear suspension, and not have thrown money away on shocks that would be replaced.I would strongly consider an upgrade to the crusader line of Viking shocks for the rear instead of the standard warrior line if I were you though.
Yeah, so you are the first to suggest a different tire, and I appreciate that. I switched from T/A Radials (which REALLY gave no traction) to the Toyo Proxes TQ drag radials when I went from the stock steel 15" Rallye wheels to my 17" aluminum Rallye wheels. I was looking for tires that I could pull double duty with.LOSE THE RADIALS.
I went from a 3.54 to the 4.10 in it now.you need more gear
If you’re only trying for high 12’s, I think with some tuning and more practice you can get there.
I seem to be the guy that is always rowing in the opposite direction from everyone else. Honestly, I would stop spending $$ on suspension stuff, tune the car, practice driving it. Done.
All of the replies are appreciated!Nice looking car. Stick shift makes it even better, imo.
If you don't know, there are two sides to the timeslip, as Budnicks pointed out. the horsepower side, (mph) and the suspension side (60 ft) Looking at your time slip and what you have indicated regarding current performance, it looks to me that both sides might benefit from some attention. Assuming pretty decent air in November down where you are at, the car could maybe go 108 or maybe 110, IMO. Car weight and compression ratio matter. Find/tune the additional 20+ hp, practice to a 1.95 60 ft, and you'll be in the 12.80s.
Me and 4 friends collectively probably have 500 passes in the 13.50 to 12.70 range. We all started higher and ended lower by simply tweaking and practice. I don't think anyone spent one $ on suspension, and generally had less motor than you, at least on paper.
Really glad to see that your going to the track. Have fun.
I appreciate that, but I hope to be able to get my 6XX HP and torque motor done in 2019, but regardless, a cam change is not in the cards.a slightly smaller cam would work better.
Something that will have better grunt on the bottom after the clutch is all the way off the floor at like 2500 or so.
I’d do a small solid.
