- 10:40 AM
- Mar 28, 2014
- South Louisiana
Thanks Grant.Don't be afraid of the ClutchTamer. It's probably the most cost effective manual trans tool you can add to improve your performance at the dragstrip, especially for beginners.
A ClutchTamer launch hits softer than an automatic, but that softer hit lasts longer. Basically it takes a clutch dump launch that's short duration but hits too hard, and consistently transforms that into a softer launch with more duration. That's what makes it so easy to run radials when the hit is controlled by a ClutchTamer. Another benefit is the softer launch is far less dependent on shock adjustment, so less likely to require expensive shocks to control the softer hit.
In the end, you get a consistent dead hook launch that's quicker and far less likely to break parts. If your clutch is already too aggressive for a hi-rpm clutch dump start, you don't need more clutch to start enjoying those benefits.
Grant
Once I work through the carb issues that developed, I am getting one, for sure...
It's only $169!!
http://www.clutchtamer.com/
