bigmanjbmopar
Newb with a view
Found a really good article about setting up your timing especially on modified engines. Shows cam duration and what initial timing should be at etc. Hope this helps some one if the future.
http://www.firstfives.org/faq/timing/timing_for_modified_engines.PDF
