I have searched the forums but could not really figure this out. I have a 383/727 combo in my Superbee. I have replace the carb with an Eldebrock 650 Thunder Series and it run pretty good but will stumble off the line and then go all out. Now I see there is another ajustment for the accelerator pump as this is in the middle hole at this point. Should I move this or leave it as is or is there something else I should do?
Also I bought this engine years ago and was told that the cam was not stock but I have no idea what is installed. I have it set at 10 degrees BTC as my book states but with a different came should I try something else? Again thanks for the help. Jim
