Customer of mine has a 65 Satellite. Current engine is a 73 (?) 440 with the original 65 727 cable shift trans. I will be installing a 69 727 trans. On his current set up the converter has a balance weight. The 69 trans that is going in has no balance weight, besides buying a new converter for the 69 with a weight is there a cheaper work around? Can a weight be purchased and welded to 69 converter? Can a different flex plate be purchased that has the option of adding a weight or leaving it off? Does anyone know how many grams the Mopar balance weight on the converter is?
