Sweet5ltr
Cyty, can you please tell us what heads, intake manifold, exhaust, and carburetor you're running?
You want the converter that matches the engines torque curve. Your engine is not a 8.1ltr big-block Chevy that has a torque peak @ 3,200 RPM, it's a 6.3ltr, torque production isn't impressive at 1,800-2,000 RPM; regardless of what the cam-card may tell us. With a 3.23 gear, the correct torque converter will dramatically increase performance, as it increases torque multiplication (like higher numerical rear end gearing). Reality here is, you can't go wrong with a 2,800-3,200 RPM 10" converter. I know FTI offers a lifetime warranty for $200.
Yes, you need a transmission cooler, regardless if you're running a factory / non-factory converter. Remember, when you run a transmission cooler, you'll also be increasing fluid capacity. Greatest cause of transmission failure is heat.
You may also want to opt for a deep-sump transmission pan and appropriate filter extension kit.
Here is a fairly inexpensive setup;
http://www.jegs.com/i/Mopar-Performance/312/P3690730AC/10002/-1
