Yes! Study up and use a good tool. No burrs or scuffing.is there any tricks to installing my torsion bars in my B body ?
any specific steps ?
Just remember that the bars are a system. Grease boots and lube need to be added and filled correctlyis there any tricks to installing my torsion bars in my B body ?
My original factory bars are marked left & right any idea which end goes to the front or rear as purple beeper said it would be twisting in the wrong direction if spun around the wrong wayHmmm..... if I had a driver's side bar that twists counter-clockwise as the suspension compresses....... and I turn that bar around front/back........ then it will now twist clockwise.
It will twist the SAME direction if swapped end to end.My original factory bars are marked left & right any idea which end goes to the front or rear as purple beeper said it would be twisting in the wrong direction if spun around the wrong way
aftermarket bars font dhow left right if that dn isfueMake sure you've got left/right and front/back correct. I've heard that if a bar has been twisted one direction all it's life it won't like going the other way and there's definitely two different left & right part numbers (not sure exactly why though, except maybe to keep them identified)
We don't speak ebonics here.
