hurmit4life
Hi, All-
I am taking apart the front end of my 66 Charger and will be media blasting/painting all metal components and replacing all bushings with polygraphite bushings from PST. Big front sway bar, disc brakes, etc.
I've got both steering knuckles off the car and torsion bar screws (Pre-load screws?) completely backed off, meaning the front end is 100% unloaded. I was able to get the passenger side torsion bar out using my removal tool. (lots of hammering) The drivers side bar just will not budge! I have a super beefy clamp on the bar (made from 3/8" angle iron and 1" hot rolled steel with a semi-circle milled for clamping) I have been hammering on this for hours, to the point I am deforming the angle iron. There is now a nice shallowed-out spot in the middle of the hammer surface.
This can't be a new problem, and I am sure someone out there has experienced this at least once. (Stubborn T-bar) I've soaked the torsion bar inside of its socket (at the back hex) with penetrating oil, but it still will not move. I've even moved the clamp as far back as possible, leaving only an inch or so between the clamp and the cross member to maximize the hammer blows. Nothing.
I am almost to the point where I am going to get out the cutting torch and separate that bar. (No load on it...so no chance of the system suddenly unloading and causing major damage to me or the car)
Any advice on a better way to get this thing out?
Thanks in advance for your help.
