trans rebuild time
vsj100
7:47 AM
In my 68 B Body 440 engine - I am ready to rebuild the transmission. In my past I have always done manual transmissions. Please help understand 2 things about the TF 727.
1. Using the valve body that does not require the kick down rod. What it's called and how to do?
2. Please give me the tutorial on what the "stall torque converter" means. My car will be a street cruiser not a drag racer.
As always - Thank you!
ps - with the 391 rear gears it was doing 12s at the drag strip. Now the rear end is 323. The 440 makes around 390 hp
2. Stall speed - if you floor it from a dead stop, how high will the engine rev before it launches the car. I’d “guess” 2400-2600 rpm is about stock….total guess
Stock for what? Different engines had different converters. And the more torque you have the higher the stall speed is.
Manual valvebody. They are available from most performance suppliers or a Transgo TF3 kit will convert your original VB to manual operation. You will have to shift the trans into every range you want to use-no more auto shifting.
Mike
VSJ, this book explains a lot of what you need to know to do it yourself.
