The biggest thing is are they bent right for proper fitment? Then you also need the correct dipstick for the tube. Myself I would try to find the correct tube and stick.are the transmission fill tubes for the 62-65 small block transmissions different then other years or are they somewhat interchangeable? thanks
Up till and including 1968 had the tube with the tab to bolt to the trans case. KimI think they are the only ones that bolt down into the trans case.
If you have the correct dipstick to match the tube it will read correctly. You can use a newer tube and stick that bolts to the bell housing bolt as long as it fits the chassis.ok. my concern is the dipstick reading correctly. thoughts?
What year, and model car? what engine? what transmission? 904 or 727?ok guys... thank you for ur input! but in i still dont know if the tube/stick will work ON THE FLUID LEVEL of a 1964 small block trans. i need to know that the dipstick will ready the correct fluid level. i'd rather not burn this brand new trans.
thanks!!!
Than just get the one in post 3.1964 small block A727. its going into a '57 Desoto behind an adapted 392 hemi
