1965wagon
cant get rid of the wheels i cant sell out it has to look 60s its a NSS car! but they are heavy!If those are old-school steel cragars try running an ultralite wheel...it ought to save you 10 lbs...
They make aluminum repops.... Sprinkle with a few steel shavings and some vinegar and they would look like they had been in the garage since the 70s...cant get rid of the wheels i cant sell out it has to look 60s its a NSS car! but they are heavy!
What is faceplating?........................MOyes right now i lift but i am having a 833 faceplated so then it wont be lifting on the shift and wont have any problems!
they take out the brass rings and syncros and face plate the gears like this makes it nearly impossible to miss a shiftWhat is faceplating?........................MO
longer collector extensions will take power off the top end and put it on the low end. sometimes people over gear.i think i am going to try some carb spacing first and even some different length header extensions!
judging from my mph and my 60' i feel i need to make up more in the 60' then on the top end!longer collector extensions will take power off the top end and put it on the low end. sometimes people over gear.
Trying to learn here, I get the tire pressure but what does setting the toe in do??? Thanks cdr!the front end lifts when going down the track, look at a video of your car, get a floor jack & raise car up like it is in the video, set the toe in alignment to 0 & also air up the front tires to the maximum air pressure.
If I'm understanding correctly being that the toe was other than 0 deg, the tire would have increased drag???my car would toe in .5 more than it had at ride height when the front was lifted, I have fixed that now. some cars may toe out when lifted.
If this guy corrected all this, he would go faster .
How does face plating affect regular street driving? ..............................MOthey take out the brass rings and syncros and face plate the gears like this makes it nearly impossible to miss a shift![]()
It does change it some is not as smooth when not under WOT conditions but it is still very drive able you just have to adapt the way you drive!How does face plating affect regular street driving? ..............................MO
