74Runneer
I have an eddy 1406 600cfm carb on my 318. Rpm intake, 302 heads, headers, dual exhaust, ~340 cam, FBO ignition. When I slam the throttle pedal from dead stop or light cruise, the car bogs out and nearly dies. It idles great, cruises great and is great at WOT, but bogs down at the transition to power mode. I'm thinking it's either an accelerator pump issue or a step up spring issue.
Has anyone dealt with a similar situation? Which should I try first? If I should try accelerator pump first, which pump should I try the 1470 or a stiffer one?
16 mmhg at 600 rpm, looks like the carb has the blue step up springs
Thanks!
Thanks!
