TxDon
I finished another project this weekend. Like a lot of others I've had some cooling issues here in the Texas summer hell, mostly with the temps creeping up when running the A/C. I've been involved with at least three other threads on this topic (A lot of good advice, thanks!) and I decided to upgrade the fan and add a thermostatic fan clutch. The car had an 18" fixed 7-blade fan inside a factory looking shroud with a 22" opening. I found a 20" high-pitch fan and clutch on Ebay but when I tried to mount it the blades hit the lower tank on my ECP aftermarket radiator. I was stuck at that point until one of threads on here mentioned that Hayden was releasing a new shorter version fan clutch with heavy duty construction. I bought one of these from RockAuto and installed it this weekend.
After cleaning and repainting the larger fan I bolted it to the clutch and removed my fixed fan. The shorter depth dimension is accomplished by using a shorter shaft so it really tightens up the space where the mounting bolts go. Between the tight space and my 68 year old eyes it took awhile to get them started but I finally got it. There is only room for an open end wrench to tighten the bolts, wearing gloves is a good idea. Hayden supplies a brass bushing to downsize the center hole and I needed to use that. Once I got the fan on I checked clearances everywhere, it now clears the bottom tank and is centered in the shroud. The high pitch blades are about halfway into the shroud and are pretty close to the pulleys on the engine side but no interference.
I started the engine and noticed an immediate difference in air movement along with a roar when revving it up. I took it for a 20 minute ride today in sunny 90 degree weather with the air on, it stayed at 185-190 when cruising and never got above 200 when sitting which is an improvement. So far so good, I also have ordered a hood to radiator rubber seal which I did not have. Here are some photos of the fan install, the first picture shows the old fixed fan.
