69 Charger
- 7:41 AM
- Jul 1, 2022
- Havelock, North Carolina
My Charger/383 was off the road a long time, but I started the engine to warm it up periodically. On one occasion, I found the clutch disc stuck to the pressure plate or flywheel. I jacked up the rear end, started the car, revved the engine and slammed on the brakes. Stopped the engine, shifted into reverse, and repeated the process. That broke it free.Looks like I let my car sit too long, and now the clutch disk is **firmly** stuck to the flywheel. Just installed the new driveline and manually bumping the car with the clutch in and trans in 2nd gear isn't breaking it loose, maybe even to the point of turning the engine over instead of breaking it loose.
Any other ideas out there?
Or, is it possible to take off lower inspection cover and pry a little between flywheel and disk (426 hemi and A-833 setup)? Or, drop the whole engine/trans/driveline and take it apart manually--not liking that option, but might be solution of last resort.
Thanks in advance!
Michael
