Barry_Calgary
Hi All,
My 440 73 Roadrunner seems fine and does not overheat and in fact with my 160 t-stat
it runs a little on the cool side. What i'm curious about is the upper rad hose gets quite hard
after being driven up to operating temp. I thought that perhaps the rad cap may need to be changed as it has a 14-16 PSI cap so I bought a replacement and the hose is basically the same. T-stat and rad are basically new.
Is this typical as the bottom hose is a lot cooler and you can squeeze it quite easily.
