DC67
Just posting these vacuum testing tools (no affiliation) and photos in the case anyone is chasing down a vacuum leak.
In the case you have a different manifold setup, you could de-grease and use duct tape over the carburetor opening or use an 'Intake Manifold' plate like this sold on ebay: MOPAR DODGE PLYMOUTH 340/383/440/426 HEMI INTAKE MANIFOLD COVER BLACK | eBay
I realize there are other ways of checking for leaks, using soapy water or spraying carb cleaner while running the engine etc., but those methods are limited in scope. Using the smoke machine, I was able to detect a very small leak from my oil pressure sending unit and rule out leaks from hard to get to areas; like below the intake manifold, the crank shaft seals, oil pan etc.
There are other areas one needs to plug on an old engine, like the valve cover breather cap or oil dipstick, etc. can also be done with silicone plugs of various sizes. When I tried to use duct tape, it was never a perfect seal and smoke always got out.
In any case, just posting this as an idea generator for anyone doing vacuum leak diagnostics since my searching didn't yield too much. One can test virtually any system that could leak with this tool but below is my setup testing the intake manifold since it seems to be common part checked on this forum.
Best way to run the test is with valve covers off and the rocker shaft bolts loosened so all valves are closed (sealed) - I did this while running my leak-down test.
Not loosening rocker shafts should also buildup enough pressure and worth a quick try just check for anything that does show up.
- AutoLine - Pro Automotive Smoke Machine Leak Detector EVAP Vacuum Diagnostic Tester | Shop Series (Made in USA)
- AutoLine - Pro Cone and Plugs 2-in-1 Adapters | for Automotive Smoke Machine Leak Testing | Cone & Cap Plugs Function | CarbonNitrile™ | Patent Pending (Made in USA)
- High Temp Masking Supply - 1.625" x 2.00" STP10 Silicone Rubber Plugs
