747mopar
I'm starting this thread hoping someone out there has found a mini starter that will work with the Quicktime RM8073 bellhousing. The papers that came with it clearly state use OEM starter, after 2 summers I think my headers have cooked it so the hunt is on.
The problem is that they've moved the starter slightly closer to the block. If you were to lay a mini and an OE flat on the floor you'll quickly notice that even being as big as it is the OE has more wiggle room facing the block.
