EngineerDoug
OK got an update on all this. As it turns out, the starter is not defective.
The problem is improper engagement of the Bendix drive. Got out the inspection camera and observed how the Bendix drive extends when I energize the solenoid. It does not fully extend, but hits the ring gear on the converter. The gear teeth do not mesh. That explains why the starter motor does not even try to spin - the contacts inside the solenoid don't touch each other.
So I do see that the mounting holes in the starter are oversize, so there is some leeway as to how you can bolt the starter to the bellhousing. Apparently I must have initially bolted it up so the gears would engage, but somehow the starter shifted enough after several uses so that it was no longer the case. I did securely bolt the starter in place; it was not loose when I pulled it.
It appears that the starter needs to shift outboard just a small amount, and then stay there. Note the converter is a high-end custom unit - not a bottom of the barrel piece. And this issue has presented itself with 2 different starters.
Has anybody else seen this issue? Am I missing any other considerations? Thanks.
