FOUND WANTED - LA 318 basic 2bbl throttle bracket
cudak888
6:50 AM
South Florida
Feedback: +4 / =0 / -0
Thank you everyone for the pictures and info! I have been able to acquire one from a forum member - apologies to any of the ones I turned down, but I couldn't pass up one that had already been bead blasted.
One of these. Not any other type, this one from a 67-69ish two-barrel LA.
Don't need it pretty, just need it decent and cheap. I will be modifying it to fit Magnum heads, so while will meet a sledgehammer and other tools of maximum bendage, the end result will be cleaned up and will be functional, so keep that in mind (under-the-sea quality parts need not apply).
P.S.: I am getting rid of the equivalent Mopar Performance part, if anyone is looking for one. This is all so I have enough space for a HEI-type dizzy.
PM with picture and price.
I might have one on my 67 Coronet parts car, I try and take a look tomorrow
The one pictured is a 4bbl
This is a 2bbl. Pivot is farther back on 2bbl, and overall height is lower, if that matters
Thank you! I missed this entirely. Given that I still have the 2bbl linkage to the transmission and an adjustable main kickdown rod, it's probably safer to go with the two-barrel bracket, even though I have an AFB on it.
Now you've got me wondering whether the Mopar Performance part I have for my Magnum is proportioned for a 4-barrel linkage or not.
-Kurt
My 67 Coronet parts car has a 318, attached are pictures of the throttle bracket. If you want it PM me your mailing address and I'll send it to you
Bumping this back up - I screwed up. I need the 4-barrel version of the same.
-Kurt
