96Formula6sp
Found this old picture as well
That was the junkyard engine from our 2018 race out of a ramcharger that sat in the woods. It had some blow by. Enough you can see the zip tie on the dipstick to keep it in. The engine that weekend used two gallons of oil in 14 hours of racing. The new engine is not as bad. But its slinging belts and needs a catch can plus a nicer road race oil pan for those left hand corners.You might post a wanted to buy ad and see what someone has. Check the junk yards. What you need is very common. Also it looks like a lot of oil all over the place. Might be huffing out the dipstick tube. Thats no good.
The bracket is $60.... i think a serpentine system would be much more.. although i haven't priced one.That was the junkyard engine from our 2018 race out of a ramcharger that sat in the woods. It had some blow by. Enough you can see the zip tie on the dipstick to keep it in. The engine that weekend used two gallons of oil in 14 hours of racing. The new engine is not as bad. But its slinging belts and needs a catch can plus a nicer road race oil pan for those left hand corners.
The few old mopars that have gone through the yards have been ac cars with the same pully brackets as mine. So hunting a set might be hard. The few old yards died back in the 00s when the owners died.You might post a wanted to buy ad and see what someone has. Check the junk yards. What you need is very common. Also it looks like a lot of oil all over the place. Might be huffing out the dipstick tube. Thats no good.
Swap over to the March pulley system. I changed my 72 340 ten years ago to this setup and couldn’t be more pleased. Just two belts and also adds the 7 hp you lose from the v-belt setup.Hey everyone,
We are working on our enduro lemons Coronet. One of our major failures at our last race has been the v-belts on our car. We flung many belts over the weekend. Enough so that even judge Phil said to do a serpentine belt setup. So looking into swaps. Our car is still running a LA 318. Our v belt brackets are in sad shape and even with a replacement set we kept having issues. Alignment and tension were checked and we even used some nice Gates belts but nothing seemed to solve the issue. So its time to trash it all and swap it over. What are my options. I look at the Magnum stuff but its out due to the timing cover being wrong. Or can it be made to work with the older LA stuff. One idea was to just throw some money at the problem with this kit.
Small Block Chrysler Serpentine Conversion, Power Steering
Any good options? Any junkyard options?
