Water pump housing problem
t.flatt
5:57 PM
North Dakota
So, I've been scratching my head on this one. I think my housing has been cut where the power steering bracket bolts up. The pictures show that there is a 1/2" gap in the power steering brackets, it is cut at an angle compared to the rest of the holes and it sticks out only 1/4" further than the bolt hole next to it. I bought this one many years ago because I cracked the one that was on my car when it was running. Do I need a different one or am I missing something?
That top should be about 1/16" shorter than the bottom bolt housing. I "just" checked this on Wednesday for a different reason. Your's has definitely been cut or ground.
Yeah, it's 1/2" shorter!
If you decide to not make a spacer and want to replace it, I have a couple of them. PM me if interested.
Well, I bought a different housing with a casting date of February '68 #2780987. That one measures 2 7/16". Better but still not a good fit. I bought a other one with a casting date of June 23 '69 #2780987-13. That one measures 2 11/16 where the power steering bracket bolts to. And, it fits perfectly! Haljaulia! I guess there are differences.
