there's people 'in the camp'
that would say you need more free front travel (up), low isn't as bad
you need like 3.5"-5" upwards, so it can transfer the weight
disconnecting the front sway bar, will let it come up as you accelerate
unless it's in the weeds & lil' to no shock travel
&/or bigger really stiff Torsion bars
if that's the case, it'll be tough to get the weight transfer you truly need
a bit of a different animal, but for an example
my stepdads old 64 GTO H/stock
(basically stockish) '365hp' 389 4bbl, Muncie 4 speed, 4.11:1, GM 12 bolt-possi,
Borge Warner Clutch, steel wheels/hubcaps removed, stock-ish type stuff
ran mid 12s & I want to say 110-ish mph, with his 6'1" 250# ***
at Fremont back in the day (sea level track)
a solid lifter Norris cam/lifters like .477 gross lift @ 290* dur.
'that was allowed'
rear seat out, passenger side seat out, still fully carpeted & sound deadening
radio, door panels, full glass & regulators etc.
he actually left the spare in the back
claimed it was for 'weight over the tires'
Running on shitty hard, M&Hs Pie-crust bias ply stiff walled slicks 28"-29" x 9"
from the late 60's early 70's
(crap tires compared to today's compounds)
very little was done to it,
at the track carb tuning, metering rod changes, accel pump change
(old Carter Competition AFB 750cfm)
& a bit more ignition timing like 38*s total old Poncho dual point,
& a hot coil IIRC
opened the 1-3/4" long tube headers/added with like 3" x 12" extensions
(he drove the car a lot, it wasn't a racecar only)
he ran 'no front sway bar' when at the track,
the rear sway bar was left in place,
helping keep the body 'torque roll' to a min.
grant you, it's not 4,000#s either, more like 3,200#s
I know it's a different type of suspension, & brand
coil springs front & rear coils & trailing arm design
but the principles are the same,
'need to free up the front suspension & let the rear drop/plant'
(at that power level)
but it made it's best runs,
with worn-out old oil-filled Gabriel Shocks on the front
& the front end 'free to rise at launch' like 3,200-3,500 IIRC,
it never really settled down/leveled off, until about 1/2 track
it more flattened out, it still rode a bit high in the front thru the traps
best it ever planted the tire too
he later put limiter straps on it, to not let it raise too much,
& hit the bumpstops
he put some I don't remember the brand of
90/10 or 75/25 (?) racing shocks upfront
& it just barely lifted, like 2.5"-3", it never ever would hook right
he went back to the worn-out Gabriels, back to the front-end lift
& riding high front, squatting in the rear
more than one way to skin a cat/make a good pass, for what you got
a lil' ballast in the 'far rear' may help some too
good luck
