easymotorsports
I have a 72 Plymouth Satellite Sebring that I am installing a 440\727 in.
The mtr was bored .040 over and crank was turned 10/10. The mtr has LY rods, new sixpak pistons, melling hv/hp oil pump (reburred and raduised), 1/2 in oil pick up tube, 6 qrt Hemi oil pan, compcams xe268 cam,lifters, pushrods and roller timing chain. 440source heads, Harland Sharp roller rockers, edelbrock performer rpm manifold and a 780cfm Quickfuel carb. Everything is brand new minus rods, block and crank. The assembly has been balanced and blueprinted.
Here is the question: imagine the empty block is on a stand, upside down, no crank or main caps, front of engine is at your belly.
See the hole on all the mains? Well I screwed up and drilled those out to around 1/4 between the mains and cam!!! Crap, I was trying to drill the hole between mains and lifters, which I did afterwards. This was done pre machine shop work, now it's all together and I am having a stroke.
What are the consiquence's for my stupidity?
