Pushbutton automatic will stymie 99% of thieves. But that doesn't help my 69 GTX. NSS switch sounds like an easy hook up if I ever get around to it.
I use this....
The cop one is hilarious!
Actually I use a negative cut off switch and I'm in the process of re wiring the entire car..with the Ron Francis kit, the neutral safety switch will not go unless in place so...I've put in a toggle switch between the neutral safety. If off, it won't start and that switch is hidden in the console. Something a little different..
Not sure about your area, but in Tucson calling 911 takes about 6-8 minutes before anyone will answer. Was just rear ended last Monday and I was shocked that a 911 call took so long to get an answer. I actually redialed 911 twice (after numerous rings) because I thought maybe I had dialed it wrong?Normally 911 still works even if don't have service account?
metal garage, 9 millimeter, and a german shepard for catching 'ANY" noise-Rottweiler to back him up. no tow truck driver will live if he would hook up to it , for any reason.8 minutes to answer. That is bad.
Even if they are slow, they can track the location?
