383man
My first question is do you plan to build the eng or buy one already done ? There are alot of ways to go but if your building one consider the 440 or 400 stroker. Its not much more money at all to get the stroker kit and it will help some. It also makes the cam sound milder in a stroker. This is my eng as I want the Max Wedge look but I love how great it drives with the single 850 DP so for now I use this set up. I used Indy EZ heads but you can use the 440Source Stealth heads for a good price. I went with the EZ heads because they have more potential if I want to step it up some more down the road. I used dished pistons with quench for 10.6 comp and it runs on 92 pump. I also use a solid flat tappet cam but its a bit bigger then yours as I wanted to make about 600 hp. My 63 is a driver I drive all the time and I went with the 4.15 stroke crank and 440 block thats a 493 at .030 over. It has run 10.70's with only 7 passes on it so far. But you could build a milder 440 or 400 stroker and have an easy 12 or 11 second car without getting to serious. Course I save a ton of money as I build my own engines. Good luck , Ron
