[QUOTE="Evan Frucht, post:
I have a weird feeling some other part of my electrical/charging system or SOMETHING IS CAUSING MY CONDENSERS TO REPEATEDLY BURN OUT... Is that possible even?
Yes
you just described a common thing with points, runs great, then things slowly get worse and old issues show up. You replace the points and then repeat.
Some cars will go for the longest time, others will haunt you. Unfortunately that is common. Its hard to say on the quality of the reproduced part rock auto sells as well. Is it up to the standards of someone skilled who rebuilds them on a distr machine? Not likely.[/QUOTE]
IMO....
The capacity, or value, of the condenser (aka capacitor) is coordinated to the coil's primary winding current and inductive reactance. If the coil was changed to gain a higher spark voltage for more reliable ignition, the induced voltage that appears at the points, when they open, must be absorbed by the condenser. If this induced voltage exceeds the breakdown voltage of the condenser, it will eventually fail.
The sole purpose of the condenser is to absorb the induced voltage that can cause arcing at the points, impeding the charging of the coil's primary winding for the next opening, resulting in possibly erratic spark....ska "missing" under load.
There is no difference in the descriptive terminology: condenser or capacitor....they mean the same.
IF an incorrect ballast resistor is used (lower than specified value), the coil will draw an excessive amount of current, again, creating a higher primary voltage that the condenser must absorb when the points open.
NOS parts are still available on the internet.
Personally, I use NOS MOPAR OR Standard Motor Products "Blue Streak" points and condenser in my RS23V0A****** Prestolite dual point distributor. The Blue Streak points are ventilated and have the largest surface area for low resistance and longest life of almost all others commercially available.
Look to HALIFAXHOPS for nos Mopar distributor parts and service.
Just my opinion of course.
BOB RENTON
