lewtot184
looking at that flame cut i hope your not using 1009 head gaskets.
I would have to pull a head to see what head gasket he used. If I do that can the head be torqued back down on the same gasket?looking at that flame cut i hope your not using 1009 head gaskets.
Nothing wrong with the standard Felpro 8519-PT1 at your compression level. They're more forgiving of the surfaces, have a tad bigger bore size, and...they're not expensive. People like the MLS but they need the proper deck surfacing (I doubt that shop finished them to the proper RA for those style gaskets, but you could ask them if you wanted to go that route) plus they do cost a bit more....I will pull a head then. What is a preferable head gasket to use? Cometic mls?
I slotted a head like that with the 1009, I would pull a head and be sure.
In this exact case I bought a used motor and when it did that the gasket barely overhang the bore at .055 bore. Had the head welded, put 17059 on and it is still running with nitrous and never lost another gasket. I just assembled a .030 440 with 67 heads, 2.14/1.81 valves and the 1009 overhangs the exhaust valve reliefs. 8519 will work on it. 1009 is a great gasket if it fits your combo.Can you elaborate about the "problem".... as it relates to the Fel Pro 1009 Head Gasket being the culprit ?
the above posts speak for the problem. a 1009 might be ok for a small bore 361 or 413 but even then i wouldn't use them. i don't know why fel-pro still makes those pieces of crap. i use the 8519 but some prefer the marine gasket. main thing is the fire ring needs to be noticeably away from the bore. i think the burnt gasket allowed cylinder pressure in the coolant system and that's what blew the freeze plug; especially a brass plug. a 1009 with alum head and a few WOT passes (and i mean very few) and the head is torched.
I would have used 4.410” bore Cometics.
unless the OP was beating on it. Green locktite on those frostplugs for me.
