JR_Charger
Now that would be disappointing!
Never mind! Just looked it up. Torque is the exact same at 425. See pic from old Motor repair manual I have.Now that would be disappointing!
I think the biggest performance gain between magnum and non-magnum 383 occurred in the addition of the 10 3/4 torque converter in the a727. Only the hp 383 got this converter.What makes a 1971 383 magnum different from any other 383
Mine is the 330 hp version; 69 Bee, factory Air, but with 4 speed and not the 727. I presume had something to do with having factory air etc. (If I did know I have forgotten). It is painted the aqua color and not orange, which I thought was a mistake but evidently came from the factory that way on the 330 hp version.I think the biggest performance gain between magnum and non-magnum 383 occurred in the addition of the 10 3/4 torque converter in the a727. Only the hp 383 got this converter.
I was taught that the term “Magnum” is unique to Dodge high performance engines. Plymouth calls it a “Commando”.
That is correct...Not exactly hand picked. There are often Letters stamped on parts. Install piston stamped "A" in cylinder stamped "C". It was the best they could do with the quality they had. Everything was off a bit but measurable and it was easy to select looser fitting parts by selection or one that fit the best. I wouldnt exactly call it hand fitted. It was quick and simple. I had seen it, especially on some gm engines. Challenger340 got into what mopar did on a thread. Reality is they did the best they could and sent it out the door. Read post 96Nobody was hand selecting parts for thousands of HP engines
That’s about as “naturally aspirated” as you can get lolare you implying all Plymouth guys go commando?![]()
To the original question; they dropped the compression ratio and ran 346 heads.What makes a 1971 383 magnum different from any other 383
