OK, so non mopar projects....
First I scored a super clean 1987 Buick regal, I am making it protouring beast, the body is perfect so I ripped it all apart, went right through the body and primer sealed it, its about as ready as it can be for final paint, also mini tub and 9" rear end. Its sitting in my aunts garage right now, waiting for me to get another burst of ambition..
I stripped a 2014 6.0 sierra, I am using the gauge cluster, ecm, motor, tranny, and traction control from the truck (traction control is harder than it sounds, I actually have the traction control from a late model impala also, but I think the trucks will work, trick is getting the weights close. (and with the truck we can change a prom to a lot of options, the lightest 6cyl std cab short bed, to a 3500 diesel) we hope lol.. We pulled it off before and it worked awesome, I didn't invent it hot rodders are doing it all the time.. Seems no one will make a traction control system for a hot rod too much liability...
A friend of mine has a shop and worked the seat foams, installed heaters and recovered the bucket seats for me, and I found some nice power rails for the fronts. I have all the grand national body parts, painted bumpers, hood, spoilers, etc.
We built the 6.0 into a 550hp monster, and had the tranny done to match it, the rear end gear ratio hasn't been decided as of yet.
I have everything except the exhaust (gonna be power zoomies, 3" full dual, the works), wheels and tires (doing 20 in back 18 in front, over sized factory look wheels, air suspension, brakes, some a/c parts (I am using most of the stuff out of the donor truck, but not using the old parts, I will get new condenser, evaporator, lines, filter, pump. I just ordered the gas tank (custom poly tank with aero pump installed), and I need to send the steering comps to steer and gear for rebuild and tune. Besides that I have everything, I will be into the car for around $30K when its done but think about it, a 550hp 6speed, all brand new, what do you get brank new, this will have nav, really nice gut, perfect body, new everything...
The other non mopar project is actually the destruction of a toy, a while back I built a 496ci 675hp 84 Camaro, and last winters oil ana came back with bearing material level high, so I took the motor out and sure enough the bearings are not healthy at all, it wouldn't have been long before I would need a crank and a couple rods..
So I sent the crank and roller cam out for polishing, the block is getting baked and blasted, new cam bearings, new fplugs, and a fresh hone, I ordered bearings, rings, oil pump, timing set and gaskets, and the motor will go back together, BUT not going back in the Camaro
I am done with her, we dragged it to the track less and less, and it got more and more expensive of a trip. Just not worth it anymore, so Ill wrap the motor up and put it on a shelf in the shop, the tranny is also out and already wrapped, the car is going on craigslist after my son gets all the gauges, fuel system, switches, and shifter out. So that is really the destruction of a project but the heads and all the other parts are on the bench waiting for the machine shop to call and say they are done with the rest of it.
I thought I was going to have to do a valve job but the heads are perfect, I took them apart, checked the runout (its better than I remember it when we put it together) and ended up just cleaning, painting, and reassembling them with new seals, springs, locks. I also ordered a couple roller lifters they were a different color than the others around the rollers pin, I never seen that before, so I am replacing them too. The motor is really nice, I think the issue is a crack in the oil pickup, I never noticed low psi and it never tripped the alarm, and I don't know if we cracked it taking it apart or it was cracked? BUT it is now. This motor dynod almost 700hp at the crank, so she was healthy, and we only weekend warriored her 5-10 times a year for 4-5 years...
NO REGRETS though it was fun, and honestly the motor may have cost me $4000 when we built it originally, and now another $850 with parts and machine work, can't complain..
So that's it, everything else is mopar, lol...
heres what I am shooting for with my protouring gnx clone, I will be into it for $30K, but easily resale it for $80K to 100K..
