My understanding is that with the flow rates of stock iron heads or in my case, amateur ported heads, the BB Mopars often peak in the 5200-5500 rpm range. This would lead me to pick a cam that peaks a little higher, maybe 5800. I'm not interested in a cam that peaks at 4500 or at 6500. Trouble is, what works for a 440 may not be as good of a match for a 440. Yeah, the heads may be the same but the bore and especially the stroke is different. Looking at online lists, I recall that cams for Big Block Mopars are grouped together like 383-440.
This seems like they paint these engines with a broad brush.
I have heard that it is best to err on the small side with unknown combinations. I've ran four of the Mopar Performance cams...The 280/474 in a stock piston 440, the 284/484 in a .030 over 440, the 292/509 and the 528 solid in my 493. I've also ran 2 Comp Cams XE285HLs, both went flat!
The most power that I have made was with a Lunati solid....316/326...261-271 @ .050. A bit soft off idle in my 493 but it really scrammed from 2800 and up. It would be a poor choice for a 9-1 383 with stock heads though.
I may choose a cam milder than I've used before but still bigger than any stock cam. That is fine.... Plus, this engine probably won't be the only one I'll have in this car. I may switch to a 440 or maybe even a 3G Hemi someday!
