midnightrider1818
the main wire that comes from the starter relay that is the main hot for the fuse box just under the master cylinder. the oem had a fusible link in that wire. mine got cut off and just soldered together. i was wondering if i add a fusible link to that wire what amp should i go with. what the factory use or what do you guys recommend. thanks
