Whats everyone working on?
No major projects until winter, but I did recently fix the temp gauge on the GTX by replacing the aftermarket sender with an NOS one. I also figured out an issue with the tach in my ‘58 Apache, the signal wire had a pushed connector at the distributor plug.
drilling 8 holes in my rear brake drum for speed sensor magnets hall effect
Almost finished with this '34 Indian and extending the shed
I will be doing sheet metal replacement on the 68 R/T over Christmas, rr will be bolted together and driven, it’s only original paint once!
70 gtx
This week I got the cowl cover off and the replacement fitted.
Then I drilled about 200 MORE spot welds and removed the front framerails and radiator shroud.
Monday I will weld the replacement rails in. I got a front "clip" with good rails and shroud attached but the rear cross member was swiss cheese. We tacked a piece of 2x2 between the rails before removing it so we could maintain the spacing. I also welded an XV Motorsports front rail frame stiffener under the radiator to stiffen the front end of the rails.
Nice work, I will be doing my 68 Charger firewall over Christmas!
Hopefully, I'll get to work on my 66 Belvedere 2dr sedan this winter. A 440 has been on the stand for years but have a 4 speed and lots of other stuff for it....
What size is it now and what are you going to. My 30x36 we also call the shed.
The Shed is finally done. Just finished passing power, air and water around the extension.
It started as 40 x 40ft and now it's 40 x 80ft.
Getting ready to bend new rocker panels for my Hornet. The stock ones rusted out because the car had full width factory stainless steel rocker panel trim that allowed dirt and moisture to get trapped behind them.
Tom
got it blasted waiting on compressor for over a week but should be resolved today, staring on patching a few small holes tehn installing new trunk pan and tail panel.
Just to get it going --- What is everone working on?
Man!! Everyone looks real busy out there!! Good to see! Im multitasking with everything. My 70 GTX. 20+ years off and on.69 Charger R/T 440 in the machine shop. Been sitting for 20+ years I’m 64 and trying to get **** done!! lol… life’s good!!
