wsutard
I'm about ready to reinstall my front hub assembly. I took a look at the FSM and it states the following for installing the bearing nut. Should I follow these or is it not relevant anymore? I ask because when I took off the nut it was no where near 90lbs.
(1) Install wheel and drum assemblies and tighten
wheel nuts on Dart models to 55 foot-pounds, on
Charger and Coronet models, to 65 foot-pounds.
(2) Tighten wheel bearing adjusting nut (Fig. 55) to
70 inch-pounds on Dart models and 90 inch-pounds on
Coronet and Charger models, while rotating wheel.
(3) Position nut lock on adjusting nut so one pair
of cotter pin slots align with hole in spindle.
(4) Back off adjusting nut and nut lock to the next
slot and install cotter pin.
(5) Install wheel covers.
