- 11:54 AM
- Apr 13, 2012
- Granite Bay CA
Cam plug depth.
Yeah, not a real exciting topic but I'm curious. Here is the depth I had in my 440/493, as noted when I pulled it in 2022 to rebuild.
You can see, the edge of the plug is near the edge of the hole in the block.
When I knocked in the new plug after getting the engine back from the machine shop, without even thinking, I drove the new one in deeper.
For the record, here is one cam that was in the engine for awhile in the first two pictures. This one did not go bad.
It seems like the wear marks are toward the rear of each lobe. I thought that cam lobes were tapered to push the cam rearward. Wouldn't that mean that the wear marks should have been toward the front edges of the lobes?
This cam you see is in my engine now but I'm looking to swap to a roller cam.
My main question here is....How crucial is the depth of the cam plug in regards to fore/aft camshaft placement? Roller cams need a button to limit forward movement and I'm assuming the rearward movement is limited by the cam plug.
What happens if that cam plug is either in too shallow or too deep?
