which 4bl carter do u think is the best? AVS AFB TQ
which Carter is your favorite?
  • Total voters
    39
I've never had a holly that didn't leak I have a burned up car to prove that but is say the eddy is about the best my dad likes the thermojunk and my brother prefers the eddy also for useability out of the box on just about any motor and I've not seen one that took much adjustment at all now I have seen continues adjusting but never being there on the rest I have o.e that will never see light of day on any of my bees ill scrap it first
In principle, the Thermobog. However even though my AVS gets worse gas mileage and needs internal orifices to be drilled out to get its low-speed metering correct, it's stupid simple and dead reliable in the long term compared to a TQ.
My Holley 700 dbl pump was running the 1/4 mile at 14.26 thru stock ex manifolds and mufflers. Swapped on my 750 Eddy, and it slowed to 14.98 1/4 mile. The Holley works way better on the strip. Put it back on, removed the mufflers and ran a 13.66.
I agree, Holley's are a pain to get set up and stay tuned on mopars. I went to Carter Thunder 650 on my 383, gave up some hp, but it runs the same every day....set it and leave it!
If i could run TQ i would but............finding a good one and assorted jets and rod...takes alot of time. NO Holleys for me!!
Holley 700 dbl pump on 451 in RR ran 1/4 mile E T of 14.22 thru mufflers. Eddy 750 same engine ran 14.98. Then Holley 700 with no mufflers ran 13.66. Holley best at track for me.
