440rb
It will be fine. Big Cube good set of heads put a small Hyd Roller Cam in it so you don't have to adjust valves all the time and don't have to use killer valve spring pressure (easy on parts) 10:1 compression, that motor will make great power down low. You won't have to turn it hard at all. Probably shift at 6000 go through around 6500 + or -, and run 11's easy.
If you go with a small motor you will have to turn it harder to make the same power.
Like a few of us said, you may not want to race much now but if you decide down the road you want to, you will be 80 - 90% there, Cam change pump a few more point of compression and you're in the 9's.
That is good advice and exactly what we have in our '69RR, 589ci but a wedge motor, 10:1, small s/roller, race heads, tiny 950HP carb, street TCI pro 3600-4200 stall, max hp from 5500-5900, max torque@4400 and its raced and driven to track with full exhaust to rear and gone a best of 10.3's@130@3800lbs race weight, we trap@around 6200-ish with 4.10's and 10x29's. Going in the 9's will require 12.5:1, more cam or upgrade to 1.7 jesels and a Dominator but thats $$$ and no plans for that currently, it runs too good as is.
