Ranger16
10W30 Rotella with a bottle of ZDDP Plus.
Rotella used to be good for Zinc content. They have changed the formula as of a year or two ago.
I'm second guessing my choice of Brad Penn Break In oil for the initial break in after learning of the low zinc and phosphorus count compared to many other brands. Lucas Break In Oil #10631 has the highest zinc and phosphorus content offered. Am I paranoid or should I make the switch?
WOW! That's great to hear. Maybe the bottle of ZDDP Plus I add is too much zinc.This is one of the latest Rotellas
Shell Rotella T5 10W-30 API CK-4
PHOSPHORUS-----1020
ZINC------------1167
TESTED DATE: 4/12/17
LINK: https://bobistheoilguy.com/forums/u...48/Shell_Rotella_T5_10W-30_***API#Post4377748
This is adequate for many street/strip applications and no need for extra additives. Remember, during the 1950s and 60s and 70s, API set Zinc recommendations at 1000-1200ppm, e.g., API SC, SD, SE
Buy it at Walmart for $16.47 Gal. (-) $5.00 dollar Shell Rebate = One of the better values going IMO.
Talking with Penn Grade, formerly Brad Penn, he strongly suggested not to add any. It's formulated the way it is for a reason.You could add a bottle of Comp break in additive.
I agree there has to be a reason but I wonder what the reason could be. Lunati, Comp Cams, and Howards Cams all told me it's all about the zinc. Lucas tops the zinc-ometer but Penn is really down on the list with their Break In Oil.Talking with Penn Grade, formerly Brad Penn, he strongly suggested not to add any. It's formulated the way it is for a reason.
Tom Schaefer said:During the years of flat tappet engines and no government regulations, most engine oils as I recall contained about 1,100 to 1,300 ppms of zinc from ZDDP. The ZDDP played a dual role, serving as an anti-wear and an anti-oxidant additive. It can be argued that with the higher levels of ashless anti-oxidants contained in modern oils, less ZDDP would be needed for wear control alone. That said, highly loaded springs in high performance engines may require more.
The optimum level of ZDDP will vary with engine design and driving patterns. There is such a thing as too much ZDDP as it can cause deposits, but where that maximum level lies again is engine/driving dependent. If I had a high performance flat tappet engine I would probably boost the zinc to about 1,600 ppms, but as I mentioned before this is just an opinion and not based in science. There are no special blending methods and the ZDDP can be cold blended so long as it goes into solution (no phase separation or haze). Also keep in mind there are many different kinds of ZDDP with different activation temperatures and oil retention properties, so the effectiveness of an unknown ZDDP can vary.
In general, if I trust the formulator, I trust his formula, and don't mess with it. Of course this only applies if I know the formulator designed the formulation with my engine and driving in mind. If he was influenced by other factors that may be irrelevant to me, such as fuel efficiency or emissions, then a little tweaking may be justified. I would only add an additive to my oil if I understood the oil, believed it had a specific deficiency, and felt confident my addition would fix or enhance it. Since I only drive consumer cars and use premium synthetic oils, I have not used aftermarket additives.
Motor oils are carefully balance by the formulator/manufacturer and tested to verify compliance with appropriate specifications. Adding aftermarket additives to these oils may upset this balance and the results may be unpredictable. If you trust the technology of the manufacturer, then it would be prudent to leave his formulation alone.
That said, there are some exceptions. Oil manufacturers are influenced by other factors than strictly engine performance, such as the laws governing fuel economy (CAFE) and emissions (catalytic converter). These factors have resulted in thinner oils with less ZDDP anti-wear additive. The engine manufacturers have gone to great lengths to assure that these SM oils continue to provide adequate protection for the average engine driven under average conditions, but may fall short for some engines or some drivers.
There have been many credible reports of excessive camshaft wear using SM oils in high performance engines, especially those having flat tappets and highly loaded springs. I don't have any personal experience with these engines but have heard enough to believe this problem may exist and is cured with additional ZDDP. Hence if I had such an engine I would boost the ZDDP and not take a chance. Regarding adverse effects from having too much ZDDP, I would not be concerned with doses up to say 1,600 ppm Zn since high dose ZDDP oils have been in the market for many years. This is just an opinion and not based in science. How much is too much I honestly don't know, but I imagine at some point excessive amounts may lead to deposits or interference with other additives. I would think, based on history, that ZDDP is one of the safer additives for increasing the dosage, especially if the formulation was designed around the higher ZDDP dose.
In the past some motor oils contained Molybdenum Disulfide which was a dispersed solid that had a tendency to fall out of suspension. The Moly you see in modern oils is an organic compound that is fully dissolved in the oil and does not fall out.
Good read, thanks for posting, but that leads me to another question. I use ZDDP Plus, but I have never been able to find any info on exactly how much that little bottle is supposed to raise the zinc level in PPM.For what it's worth, below is a cut-and-paste from my e-mail correspondence with Tom Schaefer, retired Vice President of sales and marketing for Hatco Division, Chemtura Corporation, a producer and marketer of specialty chemicals including synthetic lubricants.
EDIT:
I think maybe I found it.
https://zddplus.com/2013/11/zddplustm-tech-brief-7-oil-additive-dosing-and-dilution/
You're paranoid. Too much can be bad too. Check out this link where a bunch of oils are tested for wear protection.......
http://www.sccoa.com/forums/showthr...nds-offer-the-best-protection-***Good-read***
"he used ASTM D 2782, the Standard Test Method for Measurement of Extreme-Pressure Properties of Lubricating Fluids (Timken Method)"
"did not precisely follow what he considered as the useless ASTM D 2782 standard."
