I have aditional loads, use the A/C and got a powerfull alt with a 900 reserve load amps battery, daily driver. Everything running safe on the stock "weak and unratted +/- 40 amps ammeter" with a allmost steady centered needle.
Guess what ? a fully discharged batt won't suck more than 40 amps ever. Chemicals inside are not able to be so fast to get the electrochemical balance back, so a 40 amps ammeter is quite enough. Of course is not safe to get running that load for long time on a car, but still ammeter is able to handle it. Still if you get a full charge or discharge reading for some time something is really wrong on the car, and a 40 amps gaue will tell you that. Then it's up to you if you decide still work on that stage, but don't blame the ammeter.
You need to know how to play with it, thats all.
Don't you replace carb gasket when they fail ? when it fails do you blame the carb ?
Don't you replace valve oil seals when they fail ? when they fail, do you blame the valves ?
Once again, that ammeter is still good, just clean tighten back the stud/shunt assembly, new isolation and done.
and yes, on a resto job, I make mantenience on everything, gauges and wiring included.
I'm wondering if you ever advertised you could be getting constant discharge readings, and back and forth needle movement when giving gas to the engine and if you really understood what it was happening there. Do You ? I'm not blamming you just wondering!
Also source everything correctly from alt side of the game, never from batt side. TIPICAL HUGE MISTAKE on ammeter equipped cars
As far you really understand how an ammeter works and what is really testing, you will appreciate the gauge.
The first mistake was factory made, calling it as ALTERNATOR gauge which really is not! is really a BATT gauge, since an alternator NEVER get discharged, is not an acumulator... charges or not. The batt is what gets charged or discharged.
Does a centered needle ( neither D or C reading ) on a running engine it means the alternator is not working ? NO, is just right the opposite! it means the alt is sourcing everything the car is needing, without get the batt sucked out. that's the perfect stage. So a centered needle on a gauge called ALTERNATOR could mean the alt is not working for lot of ppl! Ppl doesn't understand what the ammeter reading means.
and, thanks for the spell check advise. I'm not from USA and is not my mother language... I can make lot of mistakes! ( I don't see spell check on the reply box on this board, but anyway I never use it where is present... what about if you help me out on what I did wrong and I can learnt from my mistakes?
