Jaysam
ok guys sorry to sound like such a newbie on the big block subject. Im still deciding on a '65-'67 383 out of a chrysler newport or a '73-'74 440 out of a motor home ( leaning towards the 440 or both ). I went to a small car show today, and because i'm fairly new to this all, other than the distributor placed near the front of the motor i cant tell by looking the difference between a 383 and a 440. So i asked a guy there "is there a way to tell the difference?" He said "the 440's have a wider block than the 383's". "Unless it's an older 383, than it may be a wide block 383 wich are rare". Then he told me heads can be swapped back and forth but intakes can not be due to the wider block on the 440's. Again, unless its an older wide block 383, than the intakes can also be swapped back and forth. Does this sound correct or am i mistaken. But the 383 in the newport only has a 2bbl carb on it, could it still be a wide block? Im really thinking of buying both and putting the older 383 heads on the 440. Does that sound like a good decision or like a bunch of crap? Thanks for any input guys. Jason
