Wiggle signal light lever- lights go crazy?
koosh
6:31 PM
CT
Once i figured out getting brakes lights, then rear running lights…time to work on signal lights. Currently i have right side signal lights, front and rear. Nothing on the left… i DO have all 4 parking lights, but if i wiggle the signal lever, thats when the weird stuff happens…. should i order the canceling cam part of the switch, or the entire signal light switch with harness etc?
And has anyone had better luck with a particular brand of replacement switch?
Sheemaar?
Classic Industries?
Never have had an issue with a Mopar but, a Monte Carlo I had in 1978 had this problem. The turn signal lever had gotten loose, at the switch cam and was grounding out the circuit.
I’m thinking best off just buying the whole switch assembly….. was gonna buy from recommended Daniel Sterns…. but with my luck—— he doesn’t have any for 69 b body!!!
