1 Wild R/T
The autotec above says it has a 2.07 pin height, so .020 in the hole at blueprint deck heught of 10.725 . Let the compression ratio calculations begin! (Or .013, if you use 6.767 for rod length)
But blueprint height only happens if someones machined the block... At least I've never seen it.... I've seen most at .015-.025 to tall...
I've machined a few to 10.705 since a composition head gasket is typically .020 thicker than a steel shim gasket... So .020 shorter deck, .020 taller gasket, heads are at blueprint spec...
