cwhubb
I searched the forums but didnt find my answer... I went from a 750 vac holley to a 950hp dbbl pumper and the car wont idle with out a little manual throttle manipulation, it leaked so I took it in to have it fixed got it home today and it doesnt leak but it wont idle on its own, it runs till the bowls go dry then quits. it idled before I took it in, I have a 1 inch spacer on the stock manifold I dont have the linkage hooked up yet I'm waiting for the tall bracket kit to come in, the manifold brake booster hose is hooked up, the carb doesnt have a pcv port so it isnt connected to the carb. could it be a vac leak? it runs and idles smooth when I manually open the throttle and is very snappy when I rev iwhen it runs it idles rough cause of the cam an old school crane fire ball very close to the mp 509 cam, but it doesnt shut off, what do you think it is? btw the fuel pressure reads about 3.5 when it did idle albiet with the bad leaks
