A lot of newer shoes are made that way. The slot actually has a round cut in it for the older pin style lever.Also appears to be the wrong shoes...
Note the holes where the park brake lever goes in.
Ah yes, thanks, now I see.Slot above spring on right side reminds me of a GM shoe but it has been many years since I've done them.
Thanks Bob/guys, just a final thought that may be the cause of the brake pedal feeling as if the master cylinder is failing.Look up moparedtn on 6-12-22 converting back to manual adjust brakes. He has part numbers and where he got adjusters and adjuster springs.
Yes. You need to fully back off the emergency brake. Then adjust the shoes. Lastly final emergency brake adjustment. If you do not do this the first pump will require more fluid to compensate for the increased travel. You still could have a master bypassing.Thanks Bob/guys, just a final thought that may be the cause of the brake pedal feeling as if the master cylinder is failing.
when I stripped the rear brake drum off ready to remove the axle, I went round to the drivers side to get some tools and applied the E brake fully....with the brake drum off, just a routine reaction.
I was focused on the axle job and did it without thinking. Given that the brake pedal problem only emerged after I’d done this, is it possible that the brake fluid has been asked to travel too far and now created a brake pedal problem.
Sure, that adds up. I’ll get the correct springs etc and adjust and then see how it is. If not, it’s time for the disc brake swap that Ive got sat on the shelfalong with the correct Dr Diff master.Yes. You need to fully back off the emergency brake. Then adjust the shoes. Lastly final emergency brake adjustment. If you do not do this the first pump will require more fluid to compensate for the increased travel. You still could have a master bypassing.
