WTB WTB-Torsion Bar Removal tool
Bb69gts
7:30 PM
Knoxville TN
Feedback: +1 / =0 / -0
Does anybody have a torsion bar removal tool that they are willing to part with?
68-69 BBody project. TN
Thanks
I made one using steel angle and u-bolts . I can position the best way to be able to strike it with a hammer. It worked great.
Terry W.
Thanks Terry.
Just u-bolts and a steel plate.
Clever. Did the u-bolts Mar the surface of the bar?
I did something similar with a piece of heater hose in between if your worried about marking
If you notice in my photos, I used U-bolts that were almost the same width as the diameter of the torsion bar. They were actually about 1/4 inch smaller than the torsion bar. I then filed flats on the insides of the U-bolts (about 1/8" of each U-bolt threaded portion) so they were very snug to the diameter of the torsion bars. I tightened them fairly tight so there was no slippage and they tapped right out without marring the bar. A little more filed off and I could have put a wrap of tape around it. Get larger U-bolts and you could put a piece of hose over each leg of the U-bolt or a slit piece of hose on the torsion bar. It worked for me and was very inexpensive.
Terry W.
Hey thanks. I’m outside all
Day today and can’t figure out how to PM from my phone
I’ll reach out later tonight.
Yes, I have backed of the LcA adjustment and loosened the strut rods and the LCA bushing.
My body man put one in backwards and dry and I need to get them out install
Both correctly.
Thanks
