rt-man
So, I'm looking ahead to 2024 and have decided to shelve the idea of putting a 400/440 in the SSP cuz too many other things need to be changed out for a SB-BB swap. I'm thinking stroking the 360LA that's in it will give me what I'm looking for: a lower rpm, stump puller type 408, budget street build. High RPM isn't in the cards. It's pulling a heavy B-body, looking for the low-end torque of a big(ger) block without a vacuum-killing camshaft. But I have some restrictions that the speed group will get aggravated with: staying with existing 340 HP manifolds, existing cast iron heads (already ported for larger int/exh valves), existing Edelbrock Performer dual plane intake. Yes, I know I'll be giving up top end HP but am good with it.
So "budget' means what/who's stroker kit, correct cam for the parts mix, probably a bigger carb (currently 600cfm Holley/Summit knockoff), machining the bottom end for clearance. What am I missing?
**Currently a rebuilt 904 behind the combo now, but I have a SB 727 in the parts bin that will get rebuilt and go behind the stroker, get the driveshaft cut down, etc.
Thanks in advance for the recommendations. Street car only, pulling a '73 B-body.
